Are you looking for Safety Speed 10 HP Wide Belt Sander, Voltage 220, 1 Phase Model: WBS4375101? We found best price for you. Go to link below to buy the Safety Speed 10 HP Wide Belt Sander, Voltage 220, 1 Phase Model: WBS4375101 for the lowest price.
Safety Speed 10 HP Wide Belt Sander, Voltage 220, 1 Phase Model: WBS4375101 Review
I recommend Safety Speed Safety Speed 10 HP Wide Belt Sander, Voltage 220, 1 Phase Model: WBS4375101 to absolutely everyone! You just can't get any better product in relation price-quality!
Safety Speed 10 HP Wide Belt Sander, Voltage 220, 1 Phase Model: WBS4375101 Description
Wide Belt Sander, 10 HP, 220 Voltage, Phase 1, 50/60 Hz, 41 Amps, Max. Board Width 42 In., Max. Board Length Unlimited, Min. Board Length 12 In., Max. Board Thickness 7-1/4 In., Min. Board Thickness 1/8 In., Belt Size 43 In. x 75 In., Feed Speed 0 to 18 FPM, Vacuum Requirement 1000 cfm
Related posts
- Century 1/4 HP Belt Drive Motor, 3-Phase, 1140 Nameplate RPM, 200-230/460 Voltage, Frame 56 Model: H1026
- Century 2 HP Belt Drive Motor, 3-Phase, 3450 Nameplate RPM, 200-230/460 Voltage, Frame 56H Model: H844
- Dayton 1/3 HP Belt Drive Motor, Split-Phase, 1725 Nameplate RPM, 115/208-230 Voltage, Frame 48Z Model: 4K252
- Century 1/2 HP Belt Drive Motor, Split-Phase, 1725 Nameplate RPM, 115/230 Voltage, Frame 56 Model: RB2054DV2
- Century 1/2 HP Belt Drive Motor, Split-Phase, 1725 Nameplate RPM, 115/208-230 Voltage, Frame 48 Model: BF2054
- Dayton 1/3, 1/6 HP Belt Drive Motor, Split-Phase, 1725/1140 Nameplate RPM, 115 Voltage, Frame 56 Model: 5K654
- Dayton 1/3 HP Belt Drive Motor, Split-Phase, 1725 Nameplate RPM, 115 Voltage, Frame 56CZ Model: 6XH50
- 4"" x 24"" 8.8 Amp Variable Speed Belt Sander
- Baileigh Industrial Belt Sander,1-1/2 HP,220V,3600 Belt SFPM Model: ES-6100
- Siemens Bus Plug, 600VAC Voltage, 200 Amps, Phase/Wire: 3 Phase, 3 Wire, Number of Poles: 3 Model: BOS14354
- Square D Busway Plug In Unit, 240VAC Voltage, 100 Amps, Phase/Wire: 3 Phase, 3 Wire, Number of Poles: 3 Model: PBPQOR3A100
- Makita Belt Sander, 3/8 x 21, 4.4 A Model: 9032
- Dynabrade Air Disc Sander, 1.3 HP, 12,000 rpm Free Speed Model: 52635
- Dynabrade Air Belt Sander,Industrial,0.5 HP,1/4 Model: 40320
- Jet Belt Sander,6 X 48 In,1 1/2 HP,2850 SFPM Model: 414600
- Little Giant 1/20 HP Centrifugal Pump, 1 Phase, 230 Voltage Model: TE-3-MD-HC
