Back to blog
Tech Lighting 700TTENVLL5412W Envision LED Head LED 3500K 5.9 Inch 120V 12 Inch 40 Degree Single-Circuit TTRAK White
Credits to Louie Lighting
Are you looking for Tech Lighting 700TTENVLL5412W Envision LED Head LED 3500K 5.9 Inch 120V 12 Inch 40 Degree Single-Circuit TTRAK White? We found best price for you. Go to link below to buy the Tech Lighting 700TTENVLL5412W Envision LED Head LED 3500K 5.9 Inch 120V 12 Inch 40 Degree Single-Circuit TTRAK White for the lowest price.
Tech Lighting 700TTENVLL5412W Envision LED Head LED 3500K 5.9 Inch 120V 12 Inch 40 Degree Single-Circuit TTRAK White Review
I own some tools & home improvement, but Tech Lighting 700TTENVLL5412W Envision LED Head LED 3500K 5.9 Inch 120V 12 Inch 40 Degree Single-Circuit TTRAK White is my most favourite.
Tech Lighting 700TTENVLL5412W Envision LED Head LED 3500K 5.9 Inch 120V 12 Inch 40 Degree Single-Circuit TTRAK White Description
Die cast aluminum LED head, pivots vertically 90, rotates horizontally 360. Features horizontal locking mechanisms. LED module and optics are modular for ease of replacement. Front air intake design allows airflow past internal heat sink fins to rear exit vents while conserving a clean, thoughtful and seamless form. 18 watt isolated power supply sits within head to avoid further visual impact on track, dimmable digital logic controller operated in constant current mode. Field-replaceable proprietary 18 watt LED module. Three interchangeable optics: 15
Related posts
